Sponsored by:
Sponsored by:
Trouble starting on a Hill.....
Old 07-18-2005, 12:50 PM
General Jackson's Avatar
Default Trouble starting on a Hill.....
2001.5 A4 1.8T, FWD, Tip, w/ 46K
Lately I've noticed that when I park my car in my driveway and go out to start it in the morning, it has trouble cranking on the first try. It takes the second attempt before she cranks. It only happens when the car has been sitting on the incline overnight. It's pulled in straight, not backed in, with the nose of the car towards the sky.
If it's on flat ground I have no problems at all. Any ideas!?!?!
Thanks,
General Jackson
Old 07-18-2005, 01:37 PM
IdrunkI's Avatar
Default RE: Trouble starting on a Hill.....
When you park at an angle, all of the fluids are moved back. It's hard to explain, the fluids that normally are sitting flat in their containers are now pushed up at an angle. The fuel will get partially cut off from the engine. You may even have other troubles with the transmission catching if it's been sitting for a while. No real harm done to the car so long as you take it easy getting down the slope and let the car sit at idle for a minute before you take off.
Old 07-18-2005, 03:30 PM
Manic Moran's Avatar
For the sake of the experiment, back into the driveway, so that you are nose-low, and see what happens.
(Probably flood the engine, but what the hell, it's in the interest of science)
NTM
Old 07-18-2005, 04:52 PM
Ok, Good idea. I'll back it in and see what happens.
Thanks for the insight!
GJ
Old 07-18-2005, 05:07 PM
STEVE36's Avatar
He won't flood the engine.
ORIGINAL: Manic Moran
NTM
Old 07-18-2005, 07:30 PM
luvin_the_rings's Avatar
lol, the injectors wouldent open, neway, id be worried about oil pressure and correct luberication during startup, ur engine will wear alot faster if there isnt enough oil in there for startup
Old 07-19-2005, 01:16 PM
Ok, So I backed the car in last night. Same problem this morning! Whatcha think guys?
Old 07-19-2005, 01:54 PM
Skibos's Avatar
i think u need to pay for a flat driveway
jarvis29676
12-31-2013 12:23 AM
matthew.palmer
11-17-2011 10:07 PM
crystaladam08
05-23-2009 12:20 AM
Howard Mawditt
04-27-2007 06:27 AM
Delano
03-31-2006 11:17 AM
Quick Reply: Trouble starting on a Hill.....
