Troubleshooting A4 1.8T turbo
Old Dec 20, 2010 | 07:22 PM
Davidd31415's Avatar
Default Troubleshooting A4 1.8T turbo
I've been trying to troubleshoot an exhaust/gas smell coming through the heat/AC ducts on my Audi A4 1.8T for a while. I can only smell it when the car is at idle, at a stop, with the climate control fan on and not set to recirculate.
I am starting to suspect a turbo leak or some other sort of turbo failure.
Since the car does not have a turbo gauge and I have had this problem since owning it, I can not say if the turbo is functioning or not.
I know some turbos cause a "woosh" sound when boost is built. Should this be the case with the A4?
Also, should the feeling of boost be clearly noticeable when accelerating? I don't feel a "kick" after a turbo lag. I figured this vehicle's turbo may be less significant than some others.
Lastly, would an intake boost leak cause exhaust/gas fumes to leak under the hood or would the smell be more indicative of a different problem?
Thanks for any help,
David
ahoward0212
Aug 9, 2014 10:34 PM
OhioAudi
Feb 9, 2011 12:18 AM
Shortney
Oct 5, 2010 11:10 PM
vtraudt
May 28, 2010 02:15 PM
afruss2007
Oct 20, 2005 05:59 AM
