Turbo failure
Old Aug 6, 2006 | 07:19 PM
khj677turbo's Avatar
Default Turbo failure
Ok i noticed about 2 weeks after getting my audi chipped that
my car started running louder then it used to, when i open the
hood and listen by the turbo, it sounds more like a warplane
then just the normal whistle. Its not that loud but my exhaust
also sounds a little more airy or farty then normal. Also when
i step on it it seems to whine at 15-17 psi that wasnt there
before. So is this the possible end of my turbo. I have 105k miles
so i wouldnt be suprised...
Old Aug 6, 2006 | 07:39 PM
Beer Mod's Avatar
Default RE: Turbo failure
Sounds like an exhaust leak maybe the exhaust manifold gasket or a turbo gasket. It should whistle at 15-17 fo sho... The car at idle should not whistle at all cuz the turbo will not build boost even if you rev the **** out of it.
Old Aug 6, 2006 | 07:42 PM
Beer Mod's Avatar
BTW you turbo maybe gone but if it is you'll have no power at all....I mean some but next to none. Trust me if your turgo was gone you would be on here saying my car is a POS cuz I can no longer pass a semi on the freeway
Old Aug 6, 2006 | 07:50 PM
AteUrV8's Avatar
ya dude it doesnt sound like your turbo is bad YET... but turbos definately get louder and start to "whine" a little more when they are coming up to there last days, but it could possibly last you another year, or could last you another week...it just depends on how you drive it.
Old Aug 6, 2006 | 07:58 PM
Well im quite aggresive with it but i can agree
with the exhaust leak, when it was installed one
of the screws on the cat snaped and now ive
only have 2 connected to the downpipe. But
how do you fix that....
Old Aug 6, 2006 | 08:03 PM
Beer Mod's Avatar
#1 Easy out
#2 Drill and tap
#3 what ever else I may have forgot
Old Aug 6, 2006 | 09:16 PM
AteUrV8's Avatar
ORIGINAL: Beer Mod
#1 Easy out
#2 Drill and tap
exactly what he said... [:-]
Old Aug 6, 2006 | 09:24 PM
ADubyaD's Avatar
SoCal Crew Member
hopin its just the exhaust leak for you bro... good luck with the fix
Old Aug 6, 2006 | 10:48 PM
I had the feeling this would become a problem
when it was installed, but it seems the more i
drive my car or the more i jump on it, my exhaust
gets louder and louder, its nice but with the
leak or whatever its quite annoying.
Old Aug 6, 2006 | 11:34 PM
david9999's Avatar
Check under the car for an exhaust leak. the common spot is the flex joint near the front.
liverman12
Oct 10, 2012 12:55 AM
Jchockey100
Apr 16, 2012 01:34 PM
stimm32
May 16, 2011 06:56 PM
jdmaine
Apr 23, 2011 06:58 PM
Arapi
Apr 5, 2010 04:40 AM
