upper control arms
Old Jun 30, 2007 | 01:45 PM
haveaseat's Avatar
Member
Default upper control arms
Hey hows it goin guys....i gotta 01 a4 quattro and i need upper control arms....AGAIN!!!!!!!I replaced them about 18 months ago and aprx 20000 miles and they are gone again. Am i doing something causing them to break faster? Or is there possibly an aftermarket brand that makes them better than the OEM which is what i used?Any help is greatly appreciated thanks!
Old Jun 30, 2007 | 03:20 PM
auditech79's Avatar
Default RE: upper control arms
There is a spec when you replace the upper link. For instance if you didn't put the link exactly where it was before you could have put too much load on the bushing and tore it up.
When you have the stut out of the car you want to set the link at a 35-45 degree angle from the strut tower. If you set it too close to the tower you would have to put severe tension on the bushing to push it down to engage the steering arm and install the pinch bolt. That can result in the bushing wearing out 2-3 times faster. Setting the bushing too low will result in not enough tension and loose steering can result.
jdahlen24
Aug 25, 2011 03:05 PM
cardiffkid
Nov 9, 2009 06:17 PM
shadowboxer
Mar 1, 2009 01:27 PM
awreadie
Jan 4, 2009 05:54 PM
duckman
May 17, 2007 02:33 AM
