vac leak?
Old Feb 16, 2007 | 04:20 PM
new2me's Avatar
Default vac leak?
I just started my car up today and there was a high pitch whine coming from the engine bay and as it idles there is a fluctuation in rpm. I went out to the car and tapped the gas (about 500rpm) a few times and it stoped then as i go back in to warm-up it starts again.[:@]No code yet im thinking vac leak. What are your thoughts?
Old Feb 16, 2007 | 04:21 PM
i2onnel's Avatar
Default RE: vac leak?
I say grab the codes, that's always the easiest thing to do. Nearest AutoZone!
Old Feb 16, 2007 | 04:26 PM
onepoint8tee's Avatar
did you pop the hood to try andpinpoint where the high pitch whine is coming from? Doesnt sound like a vac leak. I hate to even suggest what it might be.
Old Feb 16, 2007 | 04:34 PM
new2me's Avatar
ORIGINAL: onepoint8tee
I think i know what your thinking,but I dont think its the turbo. Should'nt that be more of a consistant whine and louder. Im about to go to lunch so ill see how she's really doing.
It just stopped but im sure it's not gone. I just hope theproblem willhold off for just a bit longer till it gets somewhat warm out.
Old Feb 16, 2007 | 05:24 PM
Ya but it was a little premature for me to actually say it. Could be a noisy water pump from the cold or any bearing that might become noisy from freezing temps. But if its affecting your idle, then I would suspect something like the turbo. I dont think vac leaks cause whining noises no matter where the leak might be. Might want to take the turbo inlet hose off and try to wiggle the axle just to be sure if it happens again and you are stumped.
Old Feb 16, 2007 | 05:44 PM
new2me's Avatar
Good idea.
Car runs good, I was crusin in 4th gave it moderatethrottle and was holding10psithen dropped the hammer and held 18psi. No strange noises or weird reactions. The sound i was talking about sounded like a pinhole air leak kind of like a tire with a nail in it. Not a constant whine.
Old Feb 16, 2007 | 05:46 PM
ORIGINAL: new2me
sounded like a pinhole air leak.
Damn you must have some good ears. What about the whine?
Old Feb 16, 2007 | 05:52 PM
new2me's Avatar
The noise is better decribed as the nail in tire sound more than a whine. My mistake i was in desperate need of food!
Octane567
Aug 8, 2014 10:28 AM
vtraudt
Feb 25, 2012 11:09 AM
mikeeboy82
Jun 13, 2009 11:09 PM
inventorA6
Apr 15, 2009 06:46 AM
