Vacuum Line
Yeah as david said, there are lots of them running around the engine bay. Just look for the little hoses (3 mm I believe).
1-EVAP canister
2-From fuel tank
3-Evaporative Emission (EVAP) canister purge regulator valve -N80-
4-Check-valve for EVAP canister
Between EVAP canister and intake manifold before turbocharger
Installation position (light/dark side): Arrow points in direction of flow, as shown
5-Air cleaner
6-Turbocharger
Check boost pressure page 21-46
7-Combination valve for secondary air injection (AIR)
8-Fuel pressure regulator
9-To power brake booster
10-Check valve
11-Vacuum booster
12-To Leak Detection Pump (LDP)
13-Vacuum reservoir
14-Distributor piece
15-Check valve
16-Secondary Air Injection (AIR) solenoid valve -N112-
17-Crankcase vent
18-Check valve
19-To tank Leak Detection Pump (LDP) -V144-
20-Check valve
21-Charge air cooler
With charge air pressure sensor -G31-
22-Throttle valve control module -J338-
23-Recirculating valve for turbocharger -N249-
Checking page 21-40
24-Intake manifold
With Intake Air Temperature (IAT) sensor -G42
25-Pressure unit for boost pressure regulation
26-Wastegate bypass regulator valve -N75-
27-Mechanical recirculation valve
Checking page 21-38
28-Pressure control valve for crankcase ventilation
29-Secondary Air Injection (AIR) pump motor -V101-
Regards,
1-EVAP canister
2-From fuel tank
5-Air cleaner
6-Turbocharger
10-Check valve
11-Vacuum booster
13-Vacuum reservoir
15-Check valve
17-Crankcase vent
18-Check valve
20-Check valve
Checking page 21-40
24-Intake manifold
Checking page 21-38
Regards,
