Vacuum Line
Old Feb 20, 2005 | 05:53 AM
jblum's Avatar
Default Vacuum Line
Can anybody help me locate and check the vacuum line on a 99 A4 1.8TQM. Please help, thank you.
Jordan
Old Feb 20, 2005 | 09:03 AM
david9999's Avatar
Default RE: Vacuum Line
Ummmm, engines are full of them. They do lots of things like providing vacuum to various valves.
Old Feb 20, 2005 | 11:39 AM
Jestnomen's Avatar
6th Gear
Yeah as david said, there are lots of them running around the engine bay. Just look for the little hoses (3 mm I believe).
1-EVAP canister
2-From fuel tank
3-Evaporative Emission (EVAP) canister purge regulator valve -N80-
4-Check-valve for EVAP canister
Between EVAP canister and intake manifold before turbocharger
Installation position (light/dark side): Arrow points in direction of flow, as shown
5-Air cleaner
6-Turbocharger
Check boost pressure page 21-46
7-Combination valve for secondary air injection (AIR)
8-Fuel pressure regulator
9-To power brake booster
10-Check valve
11-Vacuum booster
12-To Leak Detection Pump (LDP)
13-Vacuum reservoir
14-Distributor piece
15-Check valve
16-Secondary Air Injection (AIR) solenoid valve -N112-
17-Crankcase vent
18-Check valve
19-To tank Leak Detection Pump (LDP) -V144-
20-Check valve
21-Charge air cooler
With charge air pressure sensor -G31-
22-Throttle valve control module -J338-
23-Recirculating valve for turbocharger -N249-
Checking page 21-40
24-Intake manifold
With Intake Air Temperature (IAT) sensor -G42
25-Pressure unit for boost pressure regulation
26-Wastegate bypass regulator valve -N75-
27-Mechanical recirculation valve
Checking page 21-38
28-Pressure control valve for crankcase ventilation
29-Secondary Air Injection (AIR) pump motor -V101-
Regards,
Old Feb 20, 2005 | 12:18 PM
aaronamericahall's Avatar
dam Jest your pretty good, thats good information
mattfort
Nov 12, 2014 07:58 PM
riydan
Sep 30, 2010 01:09 AM
sanjay.debian
Apr 30, 2009 06:15 PM
cefurod
Apr 2, 2009 08:45 PM
headshok2002
Jun 4, 2005 01:52 PM
