VDO Boost gauge (antibuzz)
Old Sep 25, 2007 | 10:19 PM
IDTrav's Avatar
Default VDO Boost gauge (antibuzz)
Hey guys,
First off thanks alot onepoint8tee for the headsup on ECStuning. Saved me $60 from the shop that was bringing it an, and should be helluvalot quicker too!
Whats the deal with this antibuzz fitting? I just noticed it and am kicking myself that maybe i shouldve ordered it but my **** has been shipped already so how loud is the sound?
Does it come from the gauge inside the cabin or from the plumbing somewhere down the line?
Thanks guys!
-Trav.
Old Sep 25, 2007 | 10:24 PM
FASTER's Avatar
Tech Slut
Default RE: VDO Boost gauge (antibuzz)
its annying at 1st but you get used to it... not really a buzzing as a weird rattle... sounds kind of like a mini alarm clock sometimes
Old Sep 25, 2007 | 10:25 PM
cincyTT's Avatar
I'm make believe
The buzzing comes from the gauge and its noticeabe at first and you will then forget aboutit. If you dont have it, dont worry since not all of them do it. If it does, people have put a filter inline with the gauge to solve the problem also.
Old Sep 26, 2007 | 10:20 AM
comfort_racing's Avatar
i bought the same guage from ECS but i bought the install kit and guage pod. it came with the anti-buzz fitting. i highly recommend it for your own sanity while driving. very annoying sound imo.
Old Sep 26, 2007 | 11:02 AM
FASTER's Avatar
Tech Slut
get some bass running through the car... problem solved
Old Sep 26, 2007 | 11:31 AM
EVOLA4's Avatar
you can buy an in-line anti buzz fitting from pepboys for around $2. Then you don't have to pay for shipping. It's in the fittings section near the back of the store usually. I have one in my car and it works fine.
Old Sep 26, 2007 | 04:39 PM
qUaTtRoA4's Avatar
the nylon tubing and T are crap...I had rediculous amounts of buzzing, so, I ordered a no, buzz T from ecs...I couldn't handle the wait for shipping (the buzz really aggrivated me, I have no tolerance for annoyin little noises) so, I made a no-buzz setup w/silicone and a new T....well, the silicone expanded a bit and I didn't trust its accuracy...so then I switched over to copper tubing and a brass T...no buzzing and will prolly last longer than the car...
gl!...i'd say install and see for yourself...
Old Sep 26, 2013 | 07:02 PM
germoneypit's Avatar
Default Thread from the dead!
I just wanted to put my two cents in on this subject. I just fixed this problem with my VDO mechanical boost gauge last night. I went to a fish aquarium store. I purchased a two way valve. It's a little plastic valve. I got two for two dollars for 1/4" tubing. I installed it under the dash because I didn't know how it would fare under the hood. Plus it is easier to adjust. So after installing it inline I adjusted it to full open with no restriction. The gauge rattled of course. While driving with the lower dash panel removed I had access to the valve. I would do an eighth of a turn and try to create the noise. I kept turning the valve closed until I could not hear the rattle any more. Now the gauge is silent and responsive, or a compromise between the two. Cabin noises are so irritating!
slackerscott04
11
Feb 21, 2007 04:46 PM
Soley4pres
Jan 31, 2007 04:08 AM
a4bsix
Jul 6, 2006 04:28 PM
greenday
May 21, 2005 12:59 AM
s4me
May 18, 2005 08:39 PM
