Very odd question. Need Help. Thanks
Old Sep 22, 2006 | 04:46 PM
techbod's Avatar
Default RE: Very odd question. Need Help. Thanks
by your answer the alternator is ok I would suggest the battery fluid levels could be a question so battery not holding the volts to crank or just barley, check the fluid levels and earth connections for good contact ( chances are the battery is bad ).
Old Sep 22, 2006 | 04:53 PM
lyubof's Avatar
Thanks once again for quick reply.... I have the maintanance free battery replaced in December 05 but it could be bad. How and where do I check the earth connection ? If you have any picture or where to find...I will really appreciate it...Thanks for all your help
Old Sep 22, 2006 | 04:59 PM
techbod's Avatar
you only have 2 wires from the battery + - the - goes to the chassis, is there such a thing as a maintenance free battery?? its common to get confused over this because the filler screws are covered with n advert ( peel it off and then you will see the fillers ) the newer batteries are gel filled so no plugs to fill and have a light on the top showing green when its ok sort of a peep hole
Old Sep 22, 2006 | 05:09 PM
lyubof's Avatar
They advertise it as maintenance free battery and I had no idea these batteries also need the fluid level to be checked. I will update you once I check the fluid lever and the “–“ cable going to chassis…I truly appreciate all your help…
Old Sep 22, 2006 | 05:12 PM
techbod's Avatar
seen it many times ( maintenance free till the warranty is out) its all down to wording
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
