vibrating when stopped!
Old Feb 10, 2006 | 03:16 PM
99AudiA4q's Avatar
Default vibrating when stopped!
So whenever i stop the car and let it idle say at a red light i feel like a vibration on the car. It feels like its the tranny. My car just recently got the tranny changed and put a new one on. You think this could cause the vibration? Wat else could cause it?
Old Feb 10, 2006 | 03:17 PM
KarlMarx's Avatar
Default RE: vibrating when stopped!
If it's a cold morning, mine will do that... [&:]
Old Feb 10, 2006 | 03:33 PM
18T's Avatar
18T
what kind of vibration? does it jerk?
Old Feb 11, 2006 | 04:38 AM
PKSJeter's Avatar
Yeah when i first start mine it vibrates too. i just bought mine so i am very weary of anything that might go wrong. so i watch the tach and it looks like it only vibrates when it idles higher than usual becuz of the cold and the car is warming up. i could be wrong but i think thats what it is. if anyone disagrees let me know so i can check it out if there is a problem.
Old Feb 12, 2006 | 08:18 PM
brewmastr's Avatar
ORIGINAL: 99AudiA4q
need some more info here buddy. umm the transmission is new or a used replacement unit? was the torque converter changed as well, shudder and vibration is usually torque converter related. ive seen situations before where wrong bolt was installed in torque converter and put a dent in the casing cuz was too long and cause torque converter clutch to rub in case. as well a clutch that wont fully disengage in the torque converter will cause vibration and maybe even stalling.
Old Feb 12, 2006 | 08:20 PM
Fieldy's Avatar
amen, i face the same type of problem on cold mornings. i dunno if its the same for you guys who experiance this, but after revving to about 4-5K, the problem goes away.
Old Feb 12, 2006 | 08:22 PM
tip5's Avatar
loose motormounts? Alittle more info please.
Old Feb 13, 2006 | 12:37 PM
hb972.8q's Avatar
did you also replace your tranny mounts when you swaped trannys. how good are your engine and snub mounts?
KBNYA4
Aug 8, 2015 10:16 AM
uzone02
Jan 4, 2014 11:13 AM
Missyo90
Nov 19, 2013 08:38 AM
grandrapidsaudi4life
Dec 21, 2008 09:53 PM
thintzen
Mar 4, 2005 05:28 PM
