Car Vibrating in the back.
Old Jul 29, 2015 | 05:27 PM
KBNYA4's Avatar
Default Car Vibrating in the back.
I have a 2001 Audi A4 2.8 Quattro.
The problem I am having is when I take off from a stop I am feeling a vibration coming from the back of the car. It only happens when I take off from a stop. Not sure what is it. I had the wheel balance and rotate and still the same problem.
Also, I'm hearing squeaking noise coming from the back while I'm driving, does not matter the road surface. Sometime I hear the squeaking it sometime I don't. If I push down on the trunk while the car is park I can hear the squeaking now. Can anyone point me in a direction of what could be the problem.
Thanks,
Kevin
Old Jul 29, 2015 | 06:07 PM
elduderino200's Avatar
Can you yank the back wheels off and see what kind of shape the shocks are in? i.e. is there any oil/fluid leaking out on to the main shaft? and while you're down there check the control arm(s). I've never replaced the rear control arms but I think it's more or less one upper piece and one lower piece - as opposed to the front arms which have 5 or 6 pieces each side
Old Aug 8, 2015 | 10:16 AM
nlinesk8s's Avatar
Squeaking is probably bushings or worn shocks. Vibration could be a locked up caliper. 2x on pulling wheels off to check.
mcanedo92588
Sep 4, 2013 07:32 AM
nhltfour
Mar 13, 2009 09:57 PM
Ajay4u
Feb 16, 2009 09:33 PM
grandrapidsaudi4life
Dec 21, 2008 09:53 PM
thintzen
Mar 4, 2005 05:28 PM
