Vibrations from stick when in first gear????
Old Nov 14, 2006 | 04:34 AM
McGuireDennis's Avatar
Default Vibrations from stick when in first gear????
Guys is this normal. I get alot of vibration from the shifter when in first gear. I mean I know there should be some vibration but mine seems like it's vibrating alot. Maybe it's cause I just picked the car up today and I'm paranoid.
Old Nov 14, 2006 | 04:36 AM
A4nicator's Avatar
Default RE: Vibrations from stick when in first gear????
maybe the bushing has gone bad or you have some loose bolts to the chassis. Year/mileage?
Old Nov 14, 2006 | 04:37 AM
1999, 77,000 engine was changed at 65,000
Old Nov 14, 2006 | 04:41 AM
A4nicator's Avatar
Then its probably a loose bolt. They would have probably dropped the entire shifter assembly as well. Im assuming it was a full motor swap (engine, tranny, shifter). I'd get under there and check it out. If its all tight, youre probably just paranoid or your bushing is bad.
Old Nov 14, 2006 | 04:43 AM
Thanks dude I'll check it out, meanwhile I'm open to any ther advice..
Old Nov 14, 2006 | 09:17 AM
nickt1216's Avatar
I have the same problem with my car. I also have a replaced engine, which was done like a few weeks ago. Is replacing the boshing complicated?
Old Nov 14, 2006 | 06:08 PM
Amze's Avatar
If your going 1k RPM, and its vibrating then thats 100% normal.. and either way 1st gear isnt that smooth for 03 A4's.. Mine is perfect to my knowledge and my 1st gear sucks *** if i force it to sit at 5k RPM, shift to 2nd or accelerate fast through 1st gear, only time you should be in first is parking or going into a garage.. off a stop light etc.. 2nd can handle anything first can for normal driving
Old Nov 14, 2006 | 06:09 PM
Amze's Avatar
Note I dont see vibrating as a issue... Mabye if it were shaking then id be worried.. thats just my opinion
alex1913
Aug 29, 2012 01:32 PM
remnaw
Sep 23, 2010 01:09 AM
saer
Jul 8, 2008 08:55 PM
adrnlnlvr
Jun 9, 2008 06:33 PM
newbuyer17
Jul 23, 2005 05:48 AM
