Vibrations from stick when in first gear????
Guys is this normal. I get alot of vibration from the shifter when in first gear. I mean I know there should be some vibration but mine seems like it's vibrating alot. Maybe it's cause I just picked the car up today and I'm paranoid.
Then its probably a loose bolt. They would have probably dropped the entire shifter assembly as well. Im assuming it was a full motor swap (engine, tranny, shifter). I'd get under there and check it out. If its all tight, youre probably just paranoid or your bushing is bad.
If your going 1k RPM, and its vibrating then thats 100% normal.. and either way 1st gear isnt that smooth for 03 A4's.. Mine is perfect to my knowledge and my 1st gear sucks *** if i force it to sit at 5k RPM, shift to 2nd or accelerate fast through 1st gear, only time you should be in first is parking or going into a garage.. off a stop light etc.. 2nd can handle anything first can for normal driving
