Warning Light in Cluster (Yellow-priority 2)
Old Jun 14, 2004 | 09:10 PM
  #21
Jestnomen's Avatar
6th Gear
Default RE: Warning Light in Cluster (Yellow-priority 2)
the check engine light is most likely unrelated to the brake light.
The testing equipment you are referring to is a Obd tool. Looks like this:
You should probably think about buying one. I think every Audi/VW owner should own one if they plan to work on their own car/save money. Basically this adapter/cable interfaces from your car's obd connector to a laptop or computer. http://Ross-Tech.com sells a complete kit for ~$250. You can get a cheaper one witih shareware software from http://www.obdtool.com.
You could also try to find someone who owns a vag to scan your car. Lots of people have joined this database who are willing to lend a hand. Check it out.
Vag Locator
Old Mar 13, 2005 | 10:11 PM
  #22
awol's Avatar
great post guys! Is this also in the FAQ's catergory? Don't forget that one will get this light when needing to replace the brake fluid. Has any one used green stuff brake pads?
Old Mar 13, 2005 | 10:25 PM
  #23
apg96's Avatar
does any of this involve bleeding the brakes or is that only when u disconnect the calipers?
Old Mar 13, 2005 | 10:51 PM
  #24
Jestnomen's Avatar
6th Gear
no you don't have to bleed the brakes to change the pads.
Old Mar 3, 2014 | 10:59 PM
  #25
garysiddhu's Avatar
i am gettin emiison control sign . i have 2007 audi a4 quattro. can someone tell me wat can be the issue n wats d solution. ?
dstoehr
May 4, 2013 10:35 AM
patrick1
Apr 1, 2013 02:53 PM
Topsy
Jan 28, 2011 01:22 AM
AckBark
Apr 21, 2010 11:51 PM
nabujam
Aug 9, 2006 09:12 AM
