Warning light - not in my manual!?
Old Sep 12, 2006 | 08:45 PM
kstrike155's Avatar
Default Warning light - not in my manual!?
Hey guys,
I was just driving along today when a warning light came on. It looks EXACTLY like the brake light malfunction indicator except without the thing in the middle.
So it just looks like a circle with parenthesis around it.
Anybody have any idea what it means? It's yellow/amber.
I checked my brake lights and they are all fine just to be sure.
-Brian
Old Sep 12, 2006 | 08:53 PM
wood_e's Avatar
Default RE: Warning light - not in my manual!?
Brake pad warning indicator?
Old Sep 12, 2006 | 09:22 PM
CRAZYHAWK's Avatar
Add brake fluid.
Old Sep 13, 2006 | 01:24 AM
david9999's Avatar
Front Brake pads worn.
Old Sep 13, 2006 | 02:56 AM
Dj Spiel's Avatar
Or your sensors is bad. Dont jump to conclusions. Same problem I ordered my sensor.
lift ur car take a look & see if it is cut in anyway or anything like that.
ORIGINAL: david9999
Old Sep 13, 2006 | 05:28 PM
CRAZYHAWK's Avatar
For this indicator to come on the connector grounds when the pads are low. There is no sensor. Brake fluid is probably low.
Old Sep 13, 2006 | 05:38 PM
techbod's Avatar
when you buy the new pads the ware sensor as its called is part of the kit, all it is is a length of wire with a plastic end so when the pads get low the plastic end is worn away and puts the light on
Old Sep 13, 2006 | 05:40 PM
CRAZYHAWK's Avatar
I wouldn't call it a sensor, it just grounds to the rotor completing a circuit.
Old Sep 13, 2006 | 09:32 PM
kstrike155's Avatar
OK so I will check the fluid and if that doesn't work then it is the front pads.
Thanks guys,
Brian
Hella
Jul 11, 2013 09:07 AM
zzr
Nov 9, 2009 05:55 AM
audia4sydney
Jan 3, 2006 03:35 PM
audi ace
Jul 22, 2005 01:53 AM
