Washer won't pump fluid
Old Jan 20, 2005 | 11:35 PM
Willfulone's Avatar
Default Washer won't pump fluid
Thought my windshield washer fluid was dry...filled it up and it won't pump fluid...not frozen...
Is there a fuse or something?...The wipers work
Tks
Peace
Willfulone
Old Jan 21, 2005 | 12:10 AM
rabthol's Avatar
Default RE: Washer won't pump fluid
Could be your pump, or a line may be cloged. Get another person to listen for the pump while you attmept to spray...Be sure they are in the firing line of the fluid just in case it comes out No, really ,just have them stick their head down near the resovoir to hear the pump..if not, replace the pump
Old Jan 21, 2005 | 12:49 AM
Jestnomen's Avatar
6th Gear
Yeah the pumps go bad all the time.
http://www.audiworld.com/tech/misc28.shtml
Old Jan 26, 2005 | 12:08 PM
gkurcon's Avatar
I have a 2004 A4 1.8T doing the same thing. It was fuse #37, I think it's labeled intelligence control. Check yours, there's a good chance that it's blown. I replaced mine and it was fine...however it seems to have blown again this morning. I'll have to replace it when I get home.
Old Jan 26, 2005 | 12:24 PM
Jestnomen's Avatar
6th Gear
Umm....a fuse that keeps blowing indicates an underlying problem. Do not just replace it. It is there to protect the circuit. Fix the problem then replace the fuse.
Old Jan 26, 2005 | 01:58 PM
clconversion's Avatar
replacing the fuse is just a tempery fix we give to customers till we can make an appointment to get them into the shop to replace the pump very common problem in the winter
MartinCieslak1
Feb 25, 2011 07:51 AM
AudimaniaA4
Jan 4, 2011 08:23 AM
mypreludeisred
Jul 18, 2009 09:06 PM
tealetm
Jan 14, 2008 03:01 PM
