waterpump belt
Old Dec 21, 2006 | 04:13 AM
messaa's Avatar
Default waterpump belt
Im sure im an idiot but i cant seem to get the new belt on the water-ppump/power steering setup. its a 98 1.8 and the accessory belts were not replaced when the timing belt was. The ribbed belts came off in a minute, but this v belt was a different story. I couldnt find a tensioner or a piviot point so i loosened the PS pulley and slid the old belt off. Now im screwed cus the new one wont go, my knucks are bleedin, and i have no ride to work. someone help
Old Dec 21, 2006 | 04:29 AM
messaa's Avatar
Default RE: waterpump belt
yes its the right belt. the old on was cracked and loose and still didnt come off easy. I just cant find a logical loosening point. someone has had to have done this before. i need pointers bad. im stuck.
Old Dec 21, 2006 | 05:52 PM
acetrebo's Avatar
There are 3 bolts on the front of the pulley. They pulley is actually 2 pieces held together by the bolts.
When I replaced mine, i had to put the rear plate on, then the belt, then the outer plate, thenput the 3 bolts back in and tighten it down.
Hope this helps. There is no tensioner, you have to remove the bolts on the water-pump pulley.
Old Dec 21, 2006 | 05:54 PM
acetrebo's Avatar
Here's a pic
[IMG]local://upfiles/12448/74DB53D8425C4E6BAA969DD5129C5120.jpg[/IMG]
Old Dec 21, 2006 | 10:49 PM
messaa's Avatar
thanks
Old Dec 22, 2006 | 03:04 PM
acetrebo's Avatar
Did you get it done?
I didn't mention, you prob have to remove the fan to get to it, if you didn't already.
Old Dec 22, 2006 | 03:29 PM
techbod's Avatar
Default RE: water pump belt
I just fed it over the pulley and turned the other pulley till it went on, saves a lot of work
aznmpr
May 22, 2008 10:33 AM
Boober
Aug 4, 2006 08:29 PM
auttiquattro
Jul 19, 2006 07:57 AM
CaliA4
Apr 17, 2006 12:35 PM
