Weird Clicking sound from Airbox CEL on too
Old Jun 15, 2006 | 12:16 AM
oleafo's Avatar
Default Weird Clicking sound from Airbox CEL on too
Need help! So I start the car today and it feels funny like like not all the cylinders arn't firing so I open her up and I find this round thing that sits on top of the airbox and it's clicking really loud and when I unplug it, it stops. Not sure what it is but and the CEL's on now...
Old Jun 17, 2006 | 10:04 PM
dankhound's Avatar
Default RE: Weird Clicking sound from Airbox CEL on too
That would be your evap purge valve. The check engine light is on because of a evap purge valve open circuit.
Old Jun 17, 2006 | 10:12 PM
onepoint8tee's Avatar
the clicking sound from that valve adtually means its working correctly. get your ecu scanned for fault codes for the cel..
Old Jun 19, 2006 | 04:43 PM
oleafo's Avatar
Finally got the CEL scanned, turns out it was a misfire in #1. It's weird, it's not doing it any more... Any ideas?
Old Jun 19, 2006 | 04:48 PM
techbod's Avatar
what the hell does #1 mean what was the acuual code??
Old Jun 19, 2006 | 04:56 PM
oleafo's Avatar
misfire in #1 cylinder, duh!
Old Jun 19, 2006 | 04:57 PM
That usually means you have a bad coil pack-which is sort of common. Check/change plugs to be sure.
Coil packs are funny. They dont just die normaly. It will start out with random missfires until one day it finally quits on you. Take care of it soon though, missfires are bad for your engine.
Old Jun 19, 2006 | 05:02 PM
oleafo's Avatar
Thanks, is there some way to check the packs? Cause right now I'll have to wait till it miss fires again before I can swap it out and test it.
Old Jun 19, 2006 | 05:10 PM
ORIGINAL: oleafo
If you have a voltmeter you can test the resistance or voltage. If its an intermitent or random thing, it might be hard to diagnose even with the right equiptment. A coil pack is like $22 I think from ECS.
Old Jun 19, 2006 | 05:23 PM
oleafo's Avatar
Guess I'll have to wait till it does it again. Thanks!
B5 Fanboy
Apr 19, 2013 12:45 PM
Dunzie182
May 19, 2006 10:34 PM
theycallmedalgo
Jan 4, 2006 03:34 AM
prodrive
Dec 24, 2005 01:59 AM
