weird clicking when i turn
Old Jan 3, 2006 | 10:45 AM
theycallmedalgo's Avatar
Default weird clicking when i turn
whenever i turn the sterring wheel usually to the left i can feel this slight clicking like the wheel is hitting something, its only at lower speeds tho.. the bumper is hanging maybe about 3/4 of an inch on the left side could this be causing the problem? thnaks
Old Jan 3, 2006 | 01:52 PM
Kellya4's Avatar
Default RE: weird clicking when i turn
That sound could mean a CV joint is going, but you said the bumper is off on the left side, unless the tire is hitting the bumper, it's not going to make a sound. I would have the CV checked on the left side.
Old Jan 3, 2006 | 04:07 PM
ecartoys's Avatar
Ditto what Kellya4 said. If the clicking is not bad you might still be able to save it by repairing/rebuilding it.
eCarToys
Old Jan 4, 2006 | 12:00 AM
juice88's Avatar
ORIGINAL: theycallmedalgo
its your control arms. mine does the exact, i mean exact same thing
Old Jan 4, 2006 | 01:24 AM
nadler's Avatar
deff. a CV shaft. im gettin mine fixed now. its gonna cost ya like 300-400 bucks depending on how much they are gonna charge for labor
Old Jan 4, 2006 | 01:28 AM
Dr!ven's Avatar
ya its your CV joint, just gotta lube it up and put new rubber thingy...
Old Jan 4, 2006 | 02:37 AM
a4anonymous's Avatar
i think i have the same problem, whenever i turn the wheel right and left, it makes like a winding noise, loud enough to heard from the outside, and you can feel slight vibration from the steering wheel, its the CV?
Old Jan 4, 2006 | 03:34 AM
ecartoys's Avatar
If it is just starting to make noise from only a small amount of play, you might be able to get away with just a boot kit(less than $25 at my store).
If you need the whole kit and kaboodle, CV joint and boot kit will set you back about $200(both inner and outer)
It is an easy DIY. All you need is basic tools, a good jack and jack stands. Leave the front wheels off the ground and replace them one side at a time so you have reference. Should not take more than 3 hours total for a beginner.
eCarToys
ORIGINAL: nadler
B5 Fanboy
Apr 19, 2013 12:45 PM
TerryK
May 11, 2009 03:15 AM
TerryK
Apr 22, 2009 12:11 PM
oleafo
Jun 19, 2006 05:23 PM
Dunzie182
May 19, 2006 10:34 PM
