Turn signal clicking
Old Apr 22, 2009 | 11:49 AM
TerryK's Avatar
Default Turn signal clicking
My turn signal continues to click for a little while after i have turned it off. the turn light does not blink it just makes a clicking noise. Is this a relay or loose bulbs? Thanks
Old Apr 23, 2009 | 12:28 AM
ImTheDevil's Avatar
Probably the relay - it's built into the hazard light button on your dash. Try it in the driveway and listen closely to the hazard button and see if it's coming from there.
Old May 4, 2009 | 12:59 PM
jakemandue's Avatar
im having the same problem as well
Old May 7, 2009 | 08:24 PM
Darkprodo's Avatar
99% sure he is right
Old May 11, 2009 | 03:15 AM
71custom's Avatar
Member
I had the same problem a while back. I thought it was the relay, so I spent $90 on it and the problem was still there. I turned out to be my turn signal stalk. Basically, gunk gets built up in the contacts which causes them to falsely activate. Had to clean them, which meant pulling the airbag, steering wheel, and signal assembly out, taking apart the signal assembly and cleaning it with Q-tips and electrical contact cleaner, then putting it back together. Not terribly difficult, but make sure you know what you're doing when pulling the air bag module out. That's the scariest part.
Jackmup
Jan 28, 2011 12:04 PM
TerryK
Apr 22, 2009 12:11 PM
rockreid
Dec 15, 2008 02:52 PM
Sabrenna
Mar 30, 2006 08:09 PM
paliracer
Feb 21, 2005 03:15 PM
