weird noises :(
Old Nov 14, 2006 | 03:32 PM
  #21
chaos92287's Avatar
Default RE: weird noises :(
but would the brakes be causing the sound when i go around the corner? i dont have the brakes applied when the sound occurs. i just had the front pads replaced like 1000 miles ago but not the back ones and they did look like they were almost done as well.
Old Nov 14, 2006 | 03:37 PM
  #22
acetrebo's Avatar
ORIGINAL: chaos92287
Could easily be a warped rotor, or worn out pad like on the rear. Is the noise coming from the front or rear??? The metal to metal sound you mentioned is typical of brake pads worn down to the metal with no pad left.
Old Nov 14, 2006 | 03:43 PM
  #23
chaos92287's Avatar
its hard to tell. the brakes have been making noise for about 1 or 2 now. i was just going to wait until i went back home cause i get all the parts at cost because of connects. thats sound is coming from the rear. kinda sounds like the new sound is coming from the front tho.
Old Nov 14, 2006 | 03:44 PM
  #24
chaos92287's Avatar
o and also another sound there sounds like there is water somewhere by the firewall. i can only hear it sometimes but when i give it a little gas in 1st gear it sounds like the waster is sloshing around. doesn't always do this tho. im beginning to hate this car[:@][:'(][>:][&o][&o]
Old Nov 14, 2006 | 04:03 PM
  #25
acetrebo's Avatar
well, the best advice I can give, is pull of the front and rear wheels and take a closer look. You dont want to be driving around on bad brakes.
Not sure about the water noise, thats a new one to me, maybe the heater core making noise?
mcclendonthaboss
Jul 27, 2009 05:22 PM
AUDI_DAN
Sep 2, 2008 06:39 AM
hyperlight900
Sep 19, 2007 04:05 PM
ReX
Aug 11, 2006 10:57 PM
a4crazy
May 24, 2006 09:11 PM
