this is a weird one.
Old Jan 30, 2007 | 05:49 PM
thepirate's Avatar
Default this is a weird one.
I turn on the blinker....it flickers real fast then slows down to normal, then just cuts off completely. I thought it might be something in the dash, so I got out and the outside lights arent flashing. I turn the blinker off and turn it back on then it works again....has anyone else had this problem? do you think the bulbs might be going bad?
Old Jan 30, 2007 | 05:52 PM
techbod's Avatar
Default RE: this is a weird one.
bad ground to the flashers
Old Jan 30, 2007 | 05:54 PM
thepirate's Avatar
I would I fix that? is it in the blinker arm? in the lights? in the dash? or should I take it to my mechanic....
Old Jan 30, 2007 | 05:57 PM
SacTown_Vlad's Avatar
change your light bulb that's what i did.
Old Jan 30, 2007 | 05:59 PM
techbod's Avatar
check all the bulbs are working and clean the connections up ( I doubt its anything to do with the lever on the steering columb or fuse/ relay related ) not uncommon for terminals to get water in and corrode
Old Jan 30, 2007 | 06:03 PM
thepirate's Avatar
Well I was in some snow over the weekend....since my Audi is a florida Audi its not used to the nasty snow cold weather....I'll look at the bulbs. If they arent dirty should I replace them? front and back?
icetab
May 5, 2013 09:18 PM
burc_o
Feb 8, 2006 10:46 AM
ByPopularDemand
Oct 25, 2005 12:20 AM
