Well, that was a waste of 3 hours...
Old Dec 7, 2006 | 03:00 AM
onepoint8tee's Avatar
Default Well, that was a waste of 3 hours...
Damnit.. I attempted to do my tie rod ends tonight since it is going to be the only day above freezing temps for a while and had no luck. The lock nut took forever to break lose and then i just couldnt get the tie rod to unscrew from the inner tie rod (actually 18mm hex bolt used to adjust toe) once i had the two bolts off by the joint. I pb blasted the crap out of it and turned on it for a good two hours. The whole time i wished i had a torch to heat it up, cuz im guessing that will do the trick. Ill have to buy one tomorrow and give it another shot, too bad the high tomorrow is supposed to be only 25 [:@]
The passenger side is where i started and gave up.. We'll see how the drivers side goes tomorrow.
Here is a pic. #1 is the area i was having problems with. Kinda hard to see though.
Old Dec 7, 2006 | 03:07 AM
Beer Mod's Avatar
Default RE: Well, that was a waste of 3 hours...
Pour penetrating oil on them 5 min or so before you reef on them again.
Old Dec 7, 2006 | 03:11 AM
ORIGINAL: Beer Mod
ya, like i said i pb blasted it, about once every 5-10 mins for almost 2 hours. I think heat is the answer.
Old Dec 7, 2006 | 03:12 AM
18T's Avatar
18T
lol blast it with a heat gun or something like a torch. get it to loosen up.
Old Dec 7, 2006 | 03:50 AM
Lazer Viking's Avatar
line painting in your area huh ?
Old Dec 7, 2006 | 04:11 AM
ORIGINAL: Lazer Viking
come again?
Old Dec 7, 2006 | 04:15 AM
fogducker's Avatar
ORIGINAL: onepoint8tee
come again?
he's referring to the yellow paint spray on the inside of your wheel well.
Old Dec 7, 2006 | 04:19 AM
ORIGINAL: fogducker
come again?
Oh... Thats not a pic of my car.. I got that off audiworld.
Old Dec 7, 2006 | 08:41 AM
techbod's Avatar
angle grinder mate your putting a new on on
[IMG]local://upfiles/12092/F9654F0F954C4F50B7C9A53A430BF955.jpg[/IMG]
Old Dec 7, 2006 | 01:33 PM
ORIGINAL: avant80@2.6
Angle grinder???? If thats some sort of cutting tool, thats not the solution.. The tie rod needs to be unscrewed from where it connects to the inner tie rod. The picture you edited where to chop is not the problem, thats a bolt that gets unscrewed. Im talking about where the tie rod connects on the inside towards the inner TR/steering rack.
