Well, that was a waste of 3 hours...
I left my blowtorch somewhere and need to get a new one, but you can get a cheap propane torch at just about any hardware store with the nozzle on it for like 10-15 bucks.
Also, you could try:
a longer wrench/breaker bar/piece of pipe over the handle,
Or a long socket / wrench on the bolt and hit the end of the handle with a rubber mallet to try and break it loose.
I dont remember mine being so hard to remove, but def. a torch will do the trick for sure.
Good luck, I know its firggen cold out there now, but at least you have a garage now!!
Yeah man, a torch is what you need. I took my car in to get an alignment a few months ago, it was taking forever so I poked my head into the garage. I saw some tech blasting my car with a torch and nearly crapped my pants, be he told me the tire rod end was frozen solid and needed to be heated up for them to do the alignment.
A six-pack probably wouldn't hurt anything either
ORIGINAL: acetrebo
ORIGINAL: onepoint8tee
ya, like i said i pb blasted it, about once every 5-10 mins for almost 2 hours. I think heat is the answer.
ORIGINAL: Beer Mod
Pour penetrating oil on them 5 min or so before you reef on them again.
My bad [&o]
SON OF A BITCH! [:@]
Ok I heated the bastard with a torch for a couple mins. until it was almost glowing, turned on it and nothing... Repeated the process 4 times and on the 5th try, the other end of the tie rod started to unscrew!! (Not the end going into the inner tie rod!) Now its stripped! The only way to get it off would be to put vice grips on the threads, but if what i have been trying didnt work, that will only strip the threads. I am completely STUCK! I cant believe heating it up didnt work!!!! The tie rod end is still in one peice and everything so i just hooked it back up, and it is driveable, but the alignment isnt right. My right tire is turned in a little to the left while my left tire is straight. Not very noticeable driving, but im sure its terrible for my tread. I am either going to beg acetrebo and arif for help, or take it to a shop. Im affraid, and guessing that if i take it to a shop, they wont be able to get the tie rod end out and will want to replace the inner tie rod to get the outter/tie rod end out. Here is a pic of what im talking about:
[IMG]local://upfiles/10408/E62974B4DEEA43A29DD9D71940A45692.jpg[/IMG]
I think im just going to suck it up and take it to a shop tomorrow morning. I really hope that they find a way to get the tie rod end out without having to take out the inner tie rod though.... I will kill a bitch if i have to pay much labor or for part$ [sm=shootshoot.gif]
thats shitty man
ORIGINAL: BadLuckAudi
thats shitty man
thats shitty man
