Well, that was a waste of 3 hours...
Damnit.. I attempted to do my tie rod ends tonight since it is going to be the only day above freezing temps for a while and had no luck. The lock nut took forever to break lose and then i just couldnt get the tie rod to unscrew from the inner tie rod (actually 18mm hex bolt used to adjust toe) once i had the two bolts off by the joint. I pb blasted the crap out of it and turned on it for a good two hours. The whole time i wished i had a torch to heat it up, cuz im guessing that will do the trick. Ill have to buy one tomorrow and give it another shot, too bad the high tomorrow is supposed to be only 25 [:@]
The passenger side is where i started and gave up.. We'll see how the drivers side goes tomorrow.
Here is a pic. #1 is the area i was having problems with. Kinda hard to see though.
ORIGINAL: Beer Mod
Pour penetrating oil on them 5 min or so before you reef on them again.
ORIGINAL: fogducker
he's referring to the yellow paint spray on the inside of your wheel well.
ORIGINAL: onepoint8tee
come again?
ORIGINAL: Lazer Viking
line painting in your area huh ?
ORIGINAL: avant80@2.6
angle grinder mate your putting a new on on
[IMG]local://upfiles/12092/F9654F0F954C4F50B7C9A53A430BF955.jpg[/IMG]
