What do these codes mean?
Old Feb 8, 2007 | 07:21 PM
brandons34's Avatar
Default What do these codes mean?
I just these codes from my 96 a4 2.8 v6 quattro
P0116
P0156
P0136
P0302
P0303
P0300
Anyone have any insight?
Old Feb 8, 2007 | 07:46 PM
swift_A4's Avatar
Default RE: What do these codes mean?
i know p0300 is random misfire, p0302-3 is misfire cylinder 2-3
16500 P0116 Engine Coolant Temperature Circuit - Range/Performance Problem A
16520 P0136 O2 Sensor Circuit - Malfunction (Bank 1 Sensor 2) A
16540 P0156 O2 Sensor Circuit - Malfunction (Bank 2 Sensor 2) A
Old Feb 8, 2007 | 07:49 PM
brandons34's Avatar
does this look like a fix-it-yourself job or a take-it-to the shop job?
Old Feb 8, 2007 | 07:50 PM
SacTown_Vlad's Avatar
p0300 - Random/Multiple Cylinder Misfire Detected
p0302 -Cyl.2 Misfire Detected
p0303 -Cyl.3 Misfire Detected
try to change coils or spark plugs not sure which one
swift_A4's Avatar
not sure on the 2.8l
if the coil packs are similar to the 1.8t i would say you can eliminate p0300-p0303 with buying new coil packs. pretty easy, other codes i am not sure. I bet someone with tech experience could get you in the right direction. sorry i am of no other help
Old Feb 8, 2007 | 07:56 PM
onepoint8tee's Avatar
A missfire will cause 02 sensor/cat codes because unburnt fuel is going into the cats and causing freakish readings. Definately check/replace plugs first. Swap the coil packs around to see if the codes follow the coil packs before buying new ones.
Old Feb 8, 2007 | 07:58 PM
techbod's Avatar
sounds like P0116 could be the cause code says coolant thermostat - poor connection - wiring - ECT sensor the stat is the first on the list
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
