whats wrong with my car
Old Jan 29, 2007 | 08:53 PM
EliteTuning1's Avatar
Default whats wrong with my car
i was just normally driving doown the road and all of a sudden i lose all boost the boost guage reads 4psi when i hit it, and you can the turbo start to spool up but it wont go past that. r these the signs of a blown turbo? anything else you think it could be
Old Jan 29, 2007 | 08:59 PM
crd945's Avatar
Default RE: whats wrong with my car
you are in limp mode, do you have a vag com so you can read the fault codes? Try turning your car off and then on again.
Old Jan 29, 2007 | 09:08 PM
i turned it back on and its still not boosting. no i dont have vagcom
Old Jan 29, 2007 | 09:14 PM
MissionCtrl's Avatar
big ol' boost leak?
Old Jan 30, 2007 | 12:04 AM
Soley4pres's Avatar
year model and mileage would help..any thing else on the car mod wise? are you chipped?
do you hear air coming out of the engine bay somewhere when you hit the gas while parked?
try dissconecting the battery for about 5 min then secure it back up..Make Sure You Have Your Radio Code though!! in the manual
try to diagnose it more.. get a vag com from someone close to your area..use the vag locator and hook it up
any codes??
Old Jan 30, 2007 | 01:22 AM
david9999's Avatar
Sounds like you have gone into LIMP mode. Get the codes read and cleared. That will likely fix the problem. Other issues could be a bad wastegate or big boost leak.
Old Jan 30, 2007 | 12:57 PM
i have an 01 1.8
chipped giac-x
intake
n75
frontmount
dv
ill get the codes read tonight
Old Jan 30, 2007 | 07:30 PM
so if i am in limp mode. if i get the codes cleared everything will be alright?
Old Jan 30, 2007 | 08:27 PM
i got my codes run and the only code it threw was either a blocked hose or leaking hose, and maf dirty or damaged.
wut does this mean
is it probably just a boost leak then. i just hit 95k.
Old Jan 31, 2007 | 01:36 AM
david9999's Avatar
Post the code numbers
asalian
Sep 25, 2010 03:39 PM
turbolove
May 11, 2009 04:48 PM
newyorkgiants44
Jul 26, 2007 02:11 PM
auDi1.8TQ
Feb 17, 2006 02:39 AM
