wheel bearings???
Old Jul 11, 2006 | 12:40 AM
ShaodwMav's Avatar
Default wheel bearings???
i think i need whell bearings....it makein a weird whining noise at 45+........what the diff in these bearings there are 3 diff colors.....whats with that?
Old Jul 12, 2006 | 01:39 AM
ShaodwMav's Avatar
Default RE: wheel bearings???
bump anyone???
Old Jul 12, 2006 | 01:45 AM
trailboss's Avatar
To ccheck your wheels bearings, goto your car and jack up a side and grab the wheel top and bottom and see if it has any play. If so its a good sign of a worn bearing. As far as the bearing link, it did not work.
Old Jul 12, 2006 | 03:28 AM
david9999's Avatar
Sounds like bearing. You will hear a grinding which gets louder with speed. Could also be a bad tire. Rotate the tires, and if the noise stays in the same location, it is a bearing. ECS sells the bearing KIT for about 50
Old Jul 12, 2006 | 03:56 AM
juice88's Avatar
ORIGINAL: david9999
is the sound also a squeeking sound? one of my wheels seems to squeek in a certain spot on the wheel when it is rotated a certain amount.
Old Jul 12, 2006 | 10:05 PM
ShaodwMav's Avatar
no squeek...just a deep whine that gets louder with speed increase is that "kit" from ecs for 1 side or both of the front....and what the diff between aeb, atw, aug, and awm engine codes???
Thrices_own
May 1, 2013 10:18 AM
mcarpen89
Jul 8, 2009 11:31 AM
raffysaudi
Oct 22, 2007 06:48 AM
mcgoey
May 9, 2007 08:31 PM
Jacek
Feb 23, 2005 12:14 PM
