When to do timing belt/tensioner on 3.0l B6 car?
Old Apr 8, 2007 | 01:42 AM
AudiOso's Avatar
Default When to do timing belt/tensioner on 3.0l B6 car?
My B6 is just under 70k on the clock. I know that the factory says the belt/tensioner are good to 105k. Anyone had any bad experiences going that long? I know the TTs don't make it much past 60k without water pump impellers cracking and tensioners failing which causes major engine damage. Anyone out there have any info?
Old Apr 8, 2007 | 02:35 AM
A4Rollin's Avatar
Default RE: When to do timing belt/tensioner on 3.0l B6 car?
dude i would change it NOW! No matter what people say you can never be too careful. I owned a b5 and the timing belt snapped at 66k when i was driving! It costed me a **** load of money and was a headache and a half!! It was the biggest waste of money to get it fixed (buy used head, get it rebuilt). The car never ran the same after that so I sold it right away...sorry for the guy that bought it. Anyways, get the timing belt done before you go through the same bullshit i went through!
Old Apr 8, 2007 | 11:05 AM
acetrebo's Avatar
You're 03, with the updated tensioner.
Most horror stories arethe b5's and the bad tensioner. The belts themselves rarely break.
It will last easy till 100k.
Change it at 90k if you are paranoid. Any sooner than that, and its like changing your brake pads when they are 1/3 worn out. No need to do it.
Old Apr 8, 2007 | 03:49 PM
CRAZYHAWK's Avatar
On both the TT and A4 you should be able to go 90K mi.
Old Apr 8, 2007 | 03:56 PM
techbod's Avatar
there is no time limit on this part as its the newer part as said but I go by rule of thumb 3 to 1 ( 3 timing belts to 1 tensioner ) but it must be checked each time a belt is changed for even the smallest movement in the bearing same as the water pump, just a guide because parts are better these days
Old Apr 8, 2007 | 03:59 PM
CRAZYHAWK's Avatar
I'd change the tensioner with every timing belt change.
Old Apr 8, 2007 | 04:05 PM
techbod's Avatar
personal choice only though ( would I ? no )
jinsojoo
Oct 30, 2012 11:22 PM
Audiguruforyou
Sep 20, 2011 01:31 AM
Yamaha4710
Jan 14, 2008 03:09 PM
mdfmr2
Jan 3, 2006 03:15 AM
