Where is the orifice tube?
Old Aug 31, 2007 | 08:25 PM
DP57's Avatar
Default Where is the orifice tube?
2000 A4 1.8T Quattro
The a/c compressor went out and I am replacing it, along with a new drier and orifice tube "restrictor" (as per the dealer's quasi-definition). Soooo...has anyone replaced this restrictor, or know where the orifice tube is? I don't see anything right off from the firewall side--is it under the dash? Anyone out there who could be a life saver? Thanks.
Old Aug 31, 2007 | 11:46 PM
SAudi's Avatar
Default RE: Where is the orifice tube?
on the A/C lines under the cabin filter it in the left side line. its really in there so you need a needle nose plier, if your going to clean and reuse it be careful not to break it.
Old Sep 1, 2007 | 03:23 AM
DP57's Avatar
No, I don't need to reuse it, but under the cabin filter all I saw was a black box with a temp sensor in it. Which general diretion am I going from there? I'm still going at this from the engine side of the firewall, right? Am I pulling the rigid a/c lines out at the firewall?
Old Sep 2, 2007 | 01:02 AM
DP57's Avatar
Got it, the joint just in front of the hi/low side ports--thanks
cekren
Jul 31, 2013 12:56 PM
DOC_DEPALMA
Jun 10, 2011 11:02 PM
Dfminc
May 8, 2008 09:09 PM
DiscoStu9
May 9, 2007 07:51 PM
1998ta__1991rs
Apr 24, 2007 10:53 PM
