Boost Controllers: pneumatic or variable orifice valve
Old May 8, 2008 | 12:49 AM
Dfminc's Avatar
Default Boost Controllers: pneumatic or variable orifice valve
Can a variable orifice valve be used inline before the factory controller to set peakboost on the audi TT? I like howwith this form of boost control, asopposed to a pneumatic system,factory boost control logic is retained, butI don't know if it works with our motronic managment. That system is a lot smarter than me So has anyone used a variable flow valve or does something like the boost machine work best with our setup? Thanks!
Old May 8, 2008 | 01:40 AM
Dfminc's Avatar
Default RE: Boost Controllers: pneumatic or variable orifice valve
ok I guess the issue comes down does the TT have closed loop boost control? The valve system only works with open loop boost control so does anyone know what the TT has?
Old May 8, 2008 | 01:48 AM
Skipponator's Avatar
Ehh, English por favor.... I think pictures would help here ha!I can't answer your question, but I do know that I am picking up and installing my TurboSmart dual stage controller in a few hours!
Old May 8, 2008 | 10:35 AM
cincyTT's Avatar
I'm make believe
all you need to know is a ball and spring by itself is to fast for the TT. If you either use a bleed or combonation bleed and B&S, you will have smooth boost control and then can dump the stock n75 (boost controller). Best mbc for the job is the turboxs hpbc
Old May 8, 2008 | 09:09 PM
Dfminc's Avatar
Thanks for the tip. You helped me out with a good deal! Looked on ebay and there was one for twenty bucks with 10 minutes remaining.
S_R_N83
Feb 14, 2013 05:22 PM
ILoveT
Aug 31, 2007 01:09 AM
Latz
Oct 9, 2006 07:09 AM
b52000a4
Apr 4, 2006 11:22 PM
H2JMC
May 30, 2005 11:36 PM
