Whining noice on initial roll
Old Nov 15, 2006 | 03:26 AM
oz2281's Avatar
Member
Default Whining noice on initial roll
Hi everyone..I've noticed that after my car is parked for a few hours; say after work - when I begin to leave the parking lot I hear a whining noise similar to what you would hear when your brake pads are worn and you depress the brake pedal. However, the noise stops once I go above 10 mph or if I apply the brakes. Can anyone shed some light into this? Thanks in advance.
Old Nov 16, 2006 | 05:38 PM
oz2281's Avatar
Member
Default RE: Whining noice on initial roll
Hey Everyone,
Correction to previous post, it's not so much a whining noise it is more like a squeaking as the wheels begin to turn on initial roll. May I say that the noise dissaperas once the car has been driven for like 10 minutes.
Thanks
Old Nov 16, 2006 | 05:57 PM
18tq_redflag's Avatar
Check your belts and make sure that they are tight and not out of place. If you havent replace them replace them.
maybe check your alternator also. Autozone will do it for free.
Old Aug 22, 2007 | 04:37 PM
superfly78209's Avatar
Member
I have the same problem. it is definately something with the brakes. any suggestions?
Old Aug 22, 2007 | 04:50 PM
promethus's Avatar
My friends nissan did the same thing.
Get the brake fluid flushed.
If that doesn't fix the problem (which it didn't on Dan's nissan)
It is most likly the calipers or the bearings have gone dry.
Hope this helps.
-C
audiguy555
Apr 18, 2015 11:41 PM
Jeff04S4
Jun 25, 2008 11:08 PM
Audinick81
Apr 30, 2008 01:40 PM
jsgrabo
Apr 1, 2008 03:26 AM
2000_S4
Jun 19, 2007 01:19 PM
