Getting whoosh from initial turbo....
Old Jun 17, 2007 | 03:26 PM
2000_S4's Avatar
Default Getting whoosh from initial turbo....
I am a new and happy owner of a 2000 S4. I have been reading about how the stock tbb ripsor comes loose. I went on a bumpy road, and ever since I am getting a woosh and loss of power from about 0-3k Rpms. The turbo is still sucking but it sounds like there is a leak in the system. I read this is easy to fix and should be fixed fast. Please guide me through the repair. I also have read to go with the upgraded samco or apr asap.
Thanks.
Old Jun 19, 2007 | 06:16 AM
Baskin 4.2l's Avatar
Default RE: Getting whoosh from initial turbo....
www.vastperformance.com Get a 2.7T pressure tester. you can check the system to see if you have a leak any where between the turbo and the intake...A must for you 2.7 guys. Or you could get a V8 no need. LOL
start there
Old Jun 19, 2007 | 10:00 AM
sooks's Avatar
yes...pressure tester is good... or see if someone has one near you... also, soapy water can be used to find a leak..
Old Jun 19, 2007 | 01:19 PM
2k S4's Avatar
First, just start at the air filter & follow all the pipes to the throttle body. Just make sure all the hoses are tight, & on all the way. When you get to the throttle body, remove the TBB, & inspect it.
WolfgangCarCare
Dec 16, 2014 02:21 PM
rjsracer
B8 Models
Jan 16, 2013 09:24 AM
sabrezx
Mar 6, 2012 05:21 AM
Jeff04S4
Jun 25, 2008 11:08 PM
oz2281
Aug 22, 2007 04:50 PM
