Who has a good scanner?
Old Oct 18, 2006 | 06:06 PM
The Bishop's Avatar
Default Who has a good scanner?
Hey guys, I just changed out abunch of sensors; AIT, coolant temp., o2's, DV, etc.. I let the computer die overnight. I now have a CEL on (no I don't have a VAG- COM, yet, $$) but I went to advanced auto and they scanned it, but their scanner didn't ditect anything (it seemed like a cheap one). Does anyone know who has a good one to get my codes reset?
Old Oct 18, 2006 | 07:50 PM
onepoint8tee's Avatar
Default RE: Who has a good scanner?
why did you let the computer die over night? And, what the hell does that even mean??
Old Oct 18, 2006 | 07:55 PM
The Bishop's Avatar
I left the battery disconnected so the ECU would reset to factory settings.
Old Oct 18, 2006 | 07:57 PM
why would you do that??
Old Oct 18, 2006 | 08:02 PM
The Bishop's Avatar
Because I just replaced some bad sensors, and I want the computer to adjust from the factory setting for the new sensors, not try to adjust back from where the bad sensors were reading.
Old Oct 18, 2006 | 08:50 PM
ORIGINAL: thebishop
The ecu will detect the proper/correct frequencies/readings when something bad is replaced with something good. When a sensor goes bad, the ecu isnt stuck thinking that a sensor is still bad even after you replace it with a good one. The ecu is constantly monitoring, reading and making adjustments. You should really never have to disconnect or reset the ecu unless you are getting chipped or are having major diagnostic troubles. Doing that is sort of a last resort option in most cases. A DV is not a sensor btw.
If it drives ok and the cel isnt flashing, id just drive it for about a week and see what happens. I bet the cel will turn off by itself.
Since you just reset the ecu, youll have to go through several drive cycles before the ecu will be ready for a scan w/codes. If the cel is still on this weekend, get scanned again maybe.
Old Oct 22, 2006 | 02:57 PM
Ponch's Avatar
If your looking for a VAG, check out http://www.steve-hall.com/cgi-bin/VAG-Locator.pl and someone near you might be able to help.
2003audiA4avant
Oct 5, 2012 06:14 AM
albaniec
May 15, 2012 04:58 AM
ondansetron
Jan 26, 2011 07:43 AM
limptimtim
Jul 2, 2008 02:13 AM
roughyear
May 10, 2005 06:37 PM
