Why is second gear grinding?
Old Feb 14, 2005 | 07:01 PM
cukilo's Avatar
Default Why is second gear grinding?
I have a 97 1.8t FWD and i recently replaced the clutch and the tranny but for some reason the second gear is not smooth and until the car has been driving for a while the 2nd gear grinds and then after the driving it becomes normal? I dont think its the syncro what else could it be?
Thanks
Old Feb 14, 2005 | 11:30 PM
david9999's Avatar
Default RE: Why is second gear grinding?
You said you replaced the clutch and the trany?
Where did you get the transmission? Was it known to be good before you installed it?
Have you checked the gear fluid for proper level? Might want to drain it and check it for metal shavings
Old Feb 16, 2005 | 12:29 PM
99AudiA4q's Avatar
maybe new tranny fluid i got mine changed yesterday it was like a day and night difference!!!!! Try going to Valvoline or places like that the service usually cost around 50-60$ around here
projlightning
Oct 10, 2007 10:21 AM
zachaTTack
Jul 26, 2007 06:50 PM
L.E.O.
Mar 25, 2007 09:35 PM
aj
Nov 22, 2006 01:34 PM
MHarrison
Sep 5, 2006 04:16 PM
