WTF is wrong with my damn climate control/blower
Old Jan 5, 2006 | 01:26 AM
bhj0887's Avatar
Default WTF is wrong with my damn climate control/blower
Let's start with that I've always had the flickering CCU display. It always worked but the display didn't show up a lot of the time, I got used to it, knew what it was set at and knew how to use it. At first the display rarely stayed on, so I pulled the bitch out and resoldered a few connections and it stays on for 90% of the time now.
The other day, the fan decided to sporadically not work, maybe more often then sporadic. If I smack the **** out of the dash it usually kicks on. It doesn't matter if it's on AUTO, MAN or what the fan speed is at, it just won't kick on until I beat the **** out of the dash.
Old Jan 5, 2006 | 01:28 AM
John_E's Avatar
Default RE: WTF is wrong with my damn climate control/blower
ORIGINAL: bhj0887
sounds just like mine ...
ORIGINAL: bhj0887
You obviously have a loose connection, either in the switch or at the fan motor itself.
Old Jan 5, 2006 | 01:31 AM
MeadowsMD's Avatar
Don't know if you happened to see my post today... but a similar situation as yours. Have you checked your turn signals and headlights to see if they are working? At first I thought only the blower was my problem... now I realize it's much more.
Let me know if you figure it out.
Old Jan 5, 2006 | 01:32 AM
a4BRZLowrider's Avatar
get a test light..and find the loose conection.
Old Jan 5, 2006 | 01:53 AM
bhj0887's Avatar
Everything else works fine, just the blower that doesn't.
I guess I'll have to see if I can get to anything without pulling the dash. [&:]
Euge82
May 18, 2012 10:31 AM
68jcode
Nov 22, 2008 09:47 AM
daschief
Mar 5, 2008 09:25 PM
dubd012
Jul 22, 2007 10:30 PM
