wuts wit this power band
Old Nov 25, 2004 | 07:31 AM
PandaXpress's Avatar
Default wuts wit this power band
i like this turbo kits but theres a be draw back
Click
why does it peak and die out at 4500 kinda sucks
Old Nov 25, 2004 | 12:11 PM
david9999's Avatar
Default RE: wuts wit this power band
Don't know. Could be set up for fast spooling and quick peaks. Says nothing about FMIC, fuel regulator or injector size. temperature increase of fuel could be limiting at higher RPM.
Old Nov 25, 2004 | 03:52 PM
King_D's Avatar
because it spools fast it sees "full boost turbulence" when the turbine is spinning its fastest it creats a barrier of some sort. one fix to this is to have the exhaust turbine clipped. You know how boost starts to decrease after a certian rpm? this is the "full boost turbulence" with a clipped turbine this is nonexistant. the turbo makes boost all the way to redline.
Scigano
Nov 14, 2010 03:49 PM
agazoo
Aug 16, 2008 04:24 PM
Mikesnewaudi7447
Feb 5, 2007 07:36 PM
monkeyporn
Oct 3, 2005 03:17 AM
twinpipes
Nov 23, 2004 04:21 PM
