"brake light" problem
Old Jun 14, 2006 | 07:03 AM
drtymune's Avatar
Default "brake light" problem
first i noticed my "brake light" symbol was on and that i had blown a bulb in the rear passenger side brake light, so i changed the bulb and checked to make sure it worked, everything worked fine except the "brake light" light was still on so i double ckecked and they were still working. so i drove off noticing that the light went away everytime i would brake, but then come back when i released the brakes along with an annoying beep. can anybody help. 99 a6 2.8q
Old Jun 14, 2006 | 03:10 PM
techbod's Avatar
Default RE: "brake light" problem
break light switch not located properly (just above the break peddle)
Old Jun 16, 2006 | 06:34 PM
drtymune's Avatar
thanks will check it out. what do you suggest i do to correct it? anotherthing i noticed is when i turn my running lights and/or headlights on my brake lights are always on, just got pulled over for that, please let me know what you think i sould do.
Old Jun 17, 2006 | 11:59 AM
dankhound's Avatar
Make sure you have the proper bulb in your car.
Old Jun 17, 2006 | 02:55 PM
AudiTech04's Avatar
If your brake lights are always ON then you should replace the brake light switch
Old Jun 19, 2006 | 05:30 AM
drtymune's Avatar
will replace brake light switch, but my brakes lights work fine when the headlights are off, but whenever i turn the headlights on thats when the brake lights stay on. ill change switch and stay posted. thanks
Tripin
Apr 12, 2013 10:15 PM
luciddream42186
Jan 25, 2012 08:13 PM
ziggy64
Mar 10, 2011 09:13 AM
peterbr1717
Aug 13, 2010 03:28 PM
smoovmusicdj
Aug 22, 2007 10:27 AM
