'01 Avant top of door not sealing
Old Apr 10, 2013 | 02:12 PM
BoyRacer0013's Avatar
Default '01 Avant top of door not sealing
I have heard about the doors sagging on the sedan. However my door doesn't seem to be sagging, it opens and closes fine but the top of the door dose not close all the way and it creates quite a bit of wind noise. All the weather stripping seems to be fine. I think the window frame may be bent outward?
Old Apr 12, 2013 | 06:57 PM
Looked at it some more today the top of the door (window frame) is definitely bent outward, any ideas how this would happen or how I should go about fixing it?
Old Apr 12, 2013 | 09:57 PM
retho78's Avatar
I would try adjusting the frame, probably just need a little height adjustment. I did that on my A6 sedan and the wind noise has cut down.
Old Apr 14, 2013 | 06:42 PM
yep, here is a picture of the gap, I'm going to adjust the window assembly tomorrow hopefully.
Old Apr 15, 2013 | 05:40 PM
Had to put a couple of washers on the rear lower bolt inside the door and it lines up perfectly now. I was amazed at how easily the door panel came off.
Old Apr 15, 2013 | 08:45 PM
retho78's Avatar
Yep, it's pretty easy ....glad you got it fixed.
louie9011
Dec 6, 2012 08:04 AM
fusion28
Mar 2, 2012 04:41 AM
A4 2000
Oct 20, 2009 11:36 PM
Disturbo
Sep 27, 2009 09:42 PM
lightningrc
Jun 2, 2006 04:33 PM
