02 Trunk release
Old Aug 27, 2006 | 03:39 PM
Foswin's Avatar
Default 02 Trunk release
It seems that the trunk release on my 02 A6 is dying - or has died. The release has stopped working from either the in-car button or from the remote. I did the door key electronics re-set thing as suggested by the dealer but -- well, it's a good thing I have fold down seat backs.
Might the problem be anything other than the trunk release motor (which I assume will be pricey)?
Old Sep 3, 2006 | 03:26 PM
dankhound's Avatar
Default RE: 02 Trunk release
There could also be a problem with the linkage. Do you hear the motor attempt to work when you hit the button? If you do you have a linkage issue. Otherwise you need a new motor.
Old Sep 4, 2006 | 09:39 PM
Foswin's Avatar
Thanks. I hear the motor, but it sounds weaker than I remember. I hoping that your suggestion of a linkage problem may be it -- that sounds less expensive than a new motor.
Old Sep 6, 2006 | 01:37 AM
dankhound's Avatar
Hmm, weak sounding motor. Thats kinda a toss up. Probably a bad motor, but the linkage could be binding causing the motor to strain which would make it quiter. Only way to know for sure is to pull the panel off and take a look.
Old Sep 6, 2006 | 04:49 PM
jic534's Avatar
I don't know if the A6 system is the same or if this will help, but I had a similiar issue on a MKIV Jetta. The motor pushed out a piston that turned a pivoted bracket that opened the trunk. The bracket was cracked at the point where the piston made contact. Replacing the bracket was very straight forward and the part was inexpensive through the VW dealer.
Old Sep 7, 2006 | 02:40 AM
dankhound's Avatar
Its a similar type system.
Old Sep 11, 2006 | 03:15 PM
Foswin's Avatar
Talk about egg on my face -- it turns out that it might have been helpful to have read the owners manual! I've had the car for 4 years and because I normally open the trunk remotely I didn't realize there are multiple positions on the key slot on the trunk itself. Apparently I must have turned it to the "D" postion which de-activates the remote operation.
A little embarrassment - but a small price to pay given the possibilty of having to do repairs.
Thanks for the input.
r88888
Apr 8, 2013 12:28 PM
mblayton
Nov 5, 2011 11:25 PM
khlota
Mar 24, 2011 09:22 AM
johnstef
Aug 18, 2009 12:47 PM
cbouslim
Dec 25, 2008 11:48 PM
