Sponsored by:
Sponsored by:
'04 A6 Avant: where does hose from headlight washer connect??
Old 06-28-2018, 10:02 PM
jdoconnell's Avatar
Default '04 A6 Avant: where does hose from headlight washer connect??
Reservoir for the windshield washers was leaking. I bought a new one and removed the old one. Much to my surprise, there were two pumps, one on the outboard side (headlights) and one on the inboard side (windshield) of the tank. I assumed the larger pump was for the windshield and the smaller one for the headlights. Wrong, it was just the opposite.
When I removed the tank, I accidentally pulled off the other end of the hose, which is attached to the headlight washer pump. (Accidentally because I had no idea if was there.) It's interesting that the two pumps snap in to indentations on the tank that are the same size as the pump diameter. Once they are snapped in, no other attachment is used., other than the
I have it all back together, which took some doing since I don't have access to a lift. Now I have one problem: I do not know what the end of the headlight washer hose should be attached to.
I'm thinking it will either connect to another hose or to a fixed connector.I would appreciate any guidance or suggestions about where I should look.
(I can send photos of the tank I removed showing the various connections. Because of the odd shape, it is very important to remember what came from where on the tank.)
infestdead
11-22-2013 10:15 AM
TTPete
02-13-2011 06:32 PM
Mad Cow
01-13-2011 12:49 PM
cmacelo121
12-17-2010 10:05 PM
Jeffla
11-25-2010 10:09 AM
Quick Reply: '04 A6 Avant: where does hose from headlight washer connect??
