18158 P1750 Power Supply Voltage Low Voltage
Old Feb 10, 2011 | 10:39 AM
sukisuru's Avatar
Default 18158 P1750 Power Supply Voltage Low Voltage
18158 P1750 Power Supply Voltage Low Voltage.
What does it mean?
Old Feb 10, 2011 | 02:59 PM
chefro's Avatar
Did you check the Carfax before you bought it - was it a "flooded" car?
If it had/has a clean carfax report, is it possible that the passenger side front footwell got flooded or wet?
I suppose the first thing I would do is check the TCU for water ingress problems. While you're there you may want to check the voltage supply at the TCU, perhaps even during cranking, to make sure it isn't going too low. If that looks good, I'd check the 2 connectors at the transmission - 1 for the Multifunction switch and 1 for the internal solenoids/sensors. Make sure there is no corrosion on the terminals. Any codes in the ECU?
Old Feb 11, 2011 | 01:53 PM
sukisuru's Avatar
No codes in the ECU and no flooding.What would be the symptoms of TCU problems?
Thank you
KinkySlayer
Oct 19, 2010 07:20 PM
a6lovely
Aug 20, 2009 03:02 PM
outlaw24
Jul 28, 2008 06:03 PM
jchaffee1
Apr 10, 2008 09:39 AM
Aliel
Mar 10, 2005 04:38 AM
