1998 a6 -- no ac or lack of it
Old Aug 7, 2006 | 11:30 PM
jenn's Avatar
Default 1998 a6 -- no ac or lack of it
I have my audi 2 years now. The a/c would start and blow for a minute and stop. So, I took it to the dealership and said they said the blower motor is the problem. But when they replace the motor have the same problem. What should i do.
Old Aug 7, 2006 | 11:46 PM
SouthboroAudiGuy's Avatar
Default RE: 1998 a6 -- no ac or lack of it
Need some more info here... If you turn the AC on while the car is running, you should still get some air flowing through the system. Is that air cold? This will determine if the AC compressor is on the fritz or if the HVAC blower is gone. Also, does the blower work when you turn the heat on?
Old Aug 11, 2006 | 11:08 PM
dankhound's Avatar
Sounds like there is a problem with the blower motor control circuit in the ac control head. Can you hear the motor running and no air blowing out or is there no motor noise whatsoever.?
aimlesspoo
B7 Models
Sep 5, 2012 10:42 PM
QuattroNW
Jun 15, 2011 06:25 PM
premierdetail
Jun 3, 2007 05:31 PM
smcacy
Dec 19, 2006 12:23 AM
t42ayj
Jun 30, 2004 01:44 PM
