1999 A6 30V 2.8L - MAF Issue
Old Nov 3, 2014 | 11:14 AM
twopedalwarrior's Avatar
Default 1999 A6 30V 2.8L - MAF Issue
Hi
I've googled this to the inth degree but not finding any concrete answers
- MAF codes appears two weeks ago, low maf signal code, running rich codes, odd rpm shifting behaviour
- Bought Ebay generic MAF, No running right codes, no low signal codes, but I have issues with the car stalling while idling, starting and driving at low speeds. Transmission has gone into limp mode a couple of times
- Re did all the vac lines over the weekend to make sure no vac leaks.
- I can make the car stall in Park just by lightly hitting the throttle.
- Disconnect MAF and Idle is Perfect and I cannot make the car stall at all.
- No codes, even with new generic MAF
Do you think that I should've bought a proper genuine MAF? Or do you think I should be troubleshooting something else?
Thank you for your input
Old Nov 5, 2014 | 09:34 AM
Ok Here is the Answer
DON'T buy the cheap ebay MAFs.
I bought the proper Hitachi OE replacement and all problems went away.
wenglish
Oct 4, 2013 08:19 AM
tcdesignguy
Nov 22, 2012 09:25 AM
hebrewzzi
May 24, 2010 11:09 AM
freakaftr8
Jan 8, 2009 12:57 PM
smoovmusicdj
Apr 19, 2008 09:23 PM
