1999 A6 Quattro 2.8 Clutch Fan Pulley Replacement
Old Nov 18, 2012 | 08:00 PM
kenhungerford's Avatar
Default 1999 A6 Quattro 2.8 Clutch Fan Pulley Replacement
While doing the timing belt, water pump and thermostat on my audi I damaged the radiator fan clutch. I am replacing it and the pulley system to be safe. How do you get the bolts from behind the pulley out. The pulley doesn't look like it comes off and the new unit comes with it attached. There are 2 bolts behind the pulley I can't get out. Any help would be appreciated.
Old Nov 19, 2012 | 12:28 PM
hxgaser's Avatar
I did the same thing some time ago.
https://www.audiforums.com/forum/aud...cement-176399/
Old Nov 20, 2012 | 08:49 AM
Thanks, but i have gotten the the fan and the clutch off. I am wondering about the pulley behind the clutch. There are 2 bolts behind the pulley that i need to remove. The only way i can see is to remove the pulley but several places say to not take the pulley off. it is part number 078121235f that i am talking about.
thanks
Old Nov 20, 2012 | 11:29 AM
hxgaser's Avatar
Pulley itself is press fit to the idler pulley bracket behind it. You don't want to pull just the pulley out.
See here for removal.
Audi A4 B5 2.8L V6 Timing Belt Replacement | Removal And Installation | | Happy Wrenching
Old Nov 20, 2012 | 12:53 PM
Thanks for that. It is very informative. Do you know how to replace the two bolts behind the pulley. I have the whole assembly off but can't figure out how to get the bolts out from behind the pulley. I have ordered a new pulley but it doesn't say anything about how to get the bolts out.
Old Nov 20, 2012 | 05:00 PM
hxgaser's Avatar
You have to put your allen bit through the openings in the pulley itself.
Old Nov 20, 2012 | 09:25 PM
Sorry my fault for not explaining it correctly. I have the pulley and mount removed from the front of the engine. Behind the pulley are 2 loose bolts that hold the entire assembly to the motor along with 2 other bolts that were not hidden. How do I get these two bolts out from behind the pulley and reuse them on the new assembly?
Old Nov 21, 2012 | 11:05 AM
Jeffla's Avatar
you don't get them out. The new assembly will have the 2 bolts already installed, just dangling there.
Old Nov 22, 2012 | 10:25 AM
Thanks. That's what I needed to know. I have to return the one I got as it didnt have the bolts.
Pbcrazy
Aug 29, 2012 05:24 PM
MrsFarrow
Jun 21, 2012 08:28 PM
frostynews05
Jul 8, 2009 01:01 PM
anna1912
Feb 6, 2009 02:06 AM
Ed1955
May 3, 2006 10:10 PM
