2000 A6 4.2 Misfire P0308 C5
Old Nov 28, 2013 | 10:45 AM
slashas's Avatar
Originally Posted by Ebenezer 4.2
Check to see if both flaps are activated when you start the car when cold, that will tell you if the misfire is related to the range of the flap intake travel affecting the timing or something else. Glad to hear you are making progress on the codes
Hello, how to check activated flaps, vacuum bank should be sucked?
Old Dec 10, 2013 | 09:18 AM
Ebenezer 4.2's Avatar
When you first start the car both black vacuum pots should be compressed, you will need to remove the plastic cover to see them. If one isn't compressed it could be a vacuum issue, or a restriction from the flaps. You can tell whether the flaps move freely by manually manipulating the pivot points with the vehicle off.
Old Dec 11, 2013 | 11:38 AM
slashas's Avatar
In my case both actuators arent compressed, inlet flaps moves without any issues with hand, suspecting vacuum, any sugesstions where to start to look?
Old Dec 12, 2013 | 10:25 PM
Trace the vacuum lines back from the pots for leaks. It could also be the black electric solenoid(s) under the pots that open/close vacuum to the pots. Good luck.
Old Dec 13, 2013 | 08:00 AM
slashas's Avatar
When engine is off if I press actuator I hear air is going out from the solenoid, shouldn't solenoid be closed? Same with engine on, seems solenoid magnet is stuck? Am I right?
Old Mar 12, 2014 | 05:27 AM
slashas's Avatar
Update, I have managed to fix vacuum issues and flaps now actuated, multiple cylinders misfire gone, only have misfire on cylinder 7, checked bank and saw 1 broken arm on inltent actuator righ side of engine where 7 cylinder is located, getting arm replaced, also I am having rough idle it is related with intlet if not fully operating? How about trotle body adaptation after arm replacement?
BD2owl
Aug 4, 2014 09:26 AM
tmarshall114
Jun 21, 2011 11:01 PM
pain777
Sep 11, 2009 08:48 PM
avantee
Oct 29, 2008 02:49 PM
lexdragunov
Apr 8, 2008 09:23 PM
