2000 A6 4.2L - Air Intake Tumble Flaps Frozen
Old Jan 30, 2011 | 01:45 PM
Skyrex's Avatar
Default 2000 A6 4.2L - Air Intake Tumble Flaps Frozen
I have a '00 A6 4.2L with 82,000 miles. The tumble flaps inside the air intake manifold are frozen closed. (Not positive on the correct terminology "tumble flaps".) These are the two rows of flaps inside the intake that are opened and closed by the vacuum actuators attached to the front of the intake. Upon inspection, I'm not able to manipulate them by hand and don't see any obstructions inside that have caused both rows of flaps to freeze up in the closed position.
Please let me know how they are installed and removed, and if I can fix the problem with the existing parts. Apparently, there is no repair kit. New intake around $1400, used $300, and no aftermarket.
No luck removing them so far. Not sure what the spring will do if released and don't want to crack the case by prying or pounding on it.
Thanks for any input you have.
Old Jan 30, 2011 | 03:49 PM
chefro's Avatar
We may be "gullible" and helpful around here, but are there any more folks at that (twice already) advertised business to post about the same merchandise-related issue, over and over again?
There's a "Merchants and Vendors" section where you can advertise those great and updated links ad nauseam.
Old Oct 28, 2011 | 10:39 PM
clandrum07's Avatar
Did you ever find a solution? I'm having the same problem with mine and not sure what the proper term is to even start looking for a fix. Thanks.
Old Nov 1, 2011 | 03:36 AM
Skyrex's Avatar
Here are two links below that will help you fix your tumble flappers. They are frequently referred to as "rails". Let me know if you need further information on the repair.
quattroworld.com Forums: fixed my binding intake runners...
http://forums.audiworld.com/showthre...ntake+manifold
jshadows69
Nov 22, 2014 02:04 PM
MelendezA32
Jan 23, 2014 02:19 PM
alexmurphy
Feb 3, 2011 02:30 PM
Colin519
Sep 19, 2006 04:55 AM
active1331
Apr 14, 2005 03:07 AM
