Sponsored by:
Sponsored by:
2001 A6 Belly Pan
Old 06-16-2009, 08:52 AM
NH_USA's Avatar
Fact - The mechanic I use for big jobs says that the belly pan is a PITA but it is important because it allows the air to flow thru the radiator and across the motor and helps keep the motor clean.
When the pan is mounted correctly it will stop some pretty heavy stuff from getting into the engine compartment. The thin plastic is actually pretty tough. It will deflect rocks, and other hard stuff from doing damage to the bottom of the motor and protect sensors from road hazzards.
It actually has a venturi affect at the trailing edge that enhances air flow through the engine compartment and lessens the air pressure (drag) at the firewall. It also lessens the turbulance under the vehicle at high speeds and makes it more stable.
These are facts- not opinion about a small amout of air or thin plastic.
Old 06-17-2009, 01:34 AM
Jackmup's Avatar
If your up north it would also help keep some of the slush and salt from being thrown up there. They are pretty low to the ground. I think the rear piece is optional because niether of my cars have them or any signs they were ever there. It looks solid anyway and would probably cover the trany pan. If I was getting a leak from my trany I would ant it on the driveway so I would se it ASAP. I would just do the front belly pan.
Old 06-17-2009, 04:05 PM
NH_USA's Avatar
LOL A belly pan is like bed pan for an AUDI!
Old 06-17-2009, 04:26 PM
ppgoal's Avatar
I stand corrected. The forum info is always helpful. And my bedpan....I mean bellypan....is still installed.
Old 06-17-2009, 10:32 PM
Jackmup's Avatar
LOL, bedpan True though.
Old 06-18-2009, 10:21 AM
twinturbosixer's Avatar
Member
HAHA wow.
Update. i love my insurance company. as luck would have it, i was behind a truck yesterday on the way home from work, and it blew out a tire. With nowhere to go, i had to hit the tire. 65mph... 30 pounds of rubber... coolness.
neways. new bumper, impact cylinders, BOTH lower skid plates, and a wheel alignment (which i needed already)...
all payed for by the trucking company. $1854.
SCORE. free bed pan ;-)
Old 06-25-2009, 09:40 AM
Default Pan
The pan is there for cooling the radiator and for pulling air out of the intercooler's by causing a negative pressure point under the car, "hense the NACA ducts" it is an aero thing not a keep the engine clean thing.
YES YOU DO NEED THIS PART, if you want the car to cool the radiator and keep the intercoolers from heat soaking while driving.
  #18
Old 06-25-2009, 11:59 AM
Midniteoyl's Avatar
Agree..
Absolutely Agree.. and something I had an debate with someone here before... Glad someone actually knows what a 'NACA Duct' is
mcicoria
05-05-2013 08:45 AM
hartsoe1
01-31-2013 10:07 AM
Quick Reply: 2001 A6 Belly Pan
