2006 A6 Brake sensor wire cut
Old Jan 22, 2010 | 12:00 PM
patc890's Avatar
Default 2006 A6 Brake sensor wire cut
The brake sensor wire on my A6 was pinched and cut. My mechanic says I need new pads.
Can I just cross the wire or something to turn the warning light off and live without the sensor?
Thanks.
Pat.
Old Jan 22, 2010 | 12:19 PM
hxgaser's Avatar
Just connect the 2 wires and you are good.
Old Jan 22, 2010 | 12:40 PM
NH_USA's Avatar
Four options
1. Reconnect the wires.
2. Replace pads
3. live with warning on dash
4. Jumper the wires together.
Do 2 if the pads are worn
Do 3 if you like lights
If you do 4 make sure you check the pads.
If the wires are long enough 1 is the best choice - use a bit of solder and heat shrink tubing to insulate the wires.
Old Jan 25, 2010 | 10:12 AM
patc890's Avatar
Hi,
Thanks for the replies. I would opt for 1 or 4. Pads are new.
I was wonder if the wires needed to be connected or disconnected.
Wasn't sure how they worked.
Thanks again.
Pat
ru-handy
Apr 30, 2010 05:14 PM
Superdug
May 30, 2008 06:18 PM
djdalfaro
Jan 4, 2007 03:20 AM
travsearle
Nov 13, 2006 03:28 PM
kstrike155
Sep 18, 2006 02:40 AM
