2006 audi a6 quattro - front doors dont lock & abs problem
Old Jun 2, 2015 | 04:40 PM
dnask8man1's Avatar
Default 2006 audi a6 quattro - front doors dont lock & abs problem
Hi, anyone who has more experience with this car I would appreciate some insight. I havn't had it that long but the front two doors dont lock from inside or with key fob, unless i use the key it will lock just the driver side door. I checked all fuses in car and they are fine. Is it likely that both actuators went bad or is there something they share in common like a relay or a control module that could be malfunctioning? I have vcds and have scanned it, I will attach a copy later when I get home today. Also, im about 95% sure the abs module is the culprit but before i replace a part I would like to get a second opinion. Car has about 111,000 miles on it, and its an intermittent abs issue. sometimes it stays off if im lucky but most of the time it comes on with the esp and abs and parking brake malfunction lights, then blinks the red brake light and says drive to nearest shop carefully.
I will check later to see if anyone has experienced any of these issues before and has a possible solution. Thank you for your input
Old Jun 4, 2015 | 06:02 PM
dnask8man1's Avatar
Here is the scan. I have since cleared most codes and am driving it to see which ones reoccur. I will confirm which codes come back, but I am still getting abs issues and the front doors still dont lock
Mileage: 178720km-111051mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61
62 65 72 77
Mileage: 178720km-111051miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F1 910 559 F HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0040
Revision: --H15--- Serial number:
Coding: 01050106190F0120
Shop #: WSC 02325 785 00200
VCID: 2E55787FB9D87351CD7-807B
2 Faults Found:
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 12
Reset counter: 40
Mileage: 178575 km
Time Indication: 0
Date: 2015.05.28
Time: 20:16:11
Freeze Frame:
RPM: 1536 /min
Mass Air / Rev.: 125.4 mg/str
Temperature: 85.5°C
Idle
Load: 20.4 %
Speed: 0.0 km/h
009220 - EVAP Leak Detection Pump Sense Circuit
P2404 - 006 - Implausible Signal
Freeze Frame:
Fault Status: 00010001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 178613 km
Time Indication: 0
Date: 2015.05.31
Time: 08:16:50
Freeze Frame:
RPM: 2464 /min
Mass Air / Rev.: 496.0 mg/str
Temperature: 72.0°C
Part Throttle
Voltage: 13.57 V
Speed: 40.0 km/h
Readiness: 0000 0100
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 P HW: 09L 927 156 A
Component: AG6 09L 3,2 FSI USA 0030
Revision: --H01--- Serial number: 4062800
Coding: 0000002
Shop #: WSC 02327 785 00200
VCID: 316F6303A8E66CA9D05-8064
1 Fault Found:
062245 - Unknown Error Code
U3325 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 39
Mileage: 178620 km
Time Indication: 0
Date: 2015.05.31
Time: 09:28:57
Freeze Frame:
RPM: 672 /min
RPM: 672 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 62.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H04 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
VCID: 2D577F73B4DE0849F4D-8078
6 Faults Found:
01435 - Brake Pressure Sensor 1 (G201)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 71
Reset counter: 184
Mileage: 177713 km
Time Indication: 0
Date: 2015.05.01
Time: 18:01:27
Freeze Frame:
Hex Value: 0x2900
Hex Value: 0x4002
Hex Value: 0x001C
Hex Value: 0xB0A9
Hex Value: 0x00FF
00265 - ABS Outlet Valve; Front Left (N102)
000 - - - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 216
Mileage: 177795 km
Time Indication: 0
Date: 2015.05.03
Time: 16:59:57
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4382
Hex Value: 0x000C
Hex Value: 0xB8AD
Hex Value: 0x00FF
01200 - ABS Valves Supply Voltage
Freeze Frame:
Fault Priority: 1
Fault Frequency: 17
Reset counter: 224
Mileage: 177804 km
Time Indication: 0
Date: 2015.05.03
Time: 21:05:38
Freeze Frame:
Hex Value: 0x22C0
Hex Value: 0x4302
Hex Value: 0x0002
Hex Value: 0x81AD
Hex Value: 0x00FF
01419 - Switch Valve 2 for Electronic Stability Program (N226)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 199
Mileage: 178175 km
Time Indication: 0
Date: 2015.05.08
Time: 15:01:36
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4306
Hex Value: 0x0017
Hex Value: 0xB8AD
Hex Value: 0x00FF
01421 - High Pressure Switch Valve 2 for Electronic Stability Program (N228)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 209
Mileage: 178448 km
Time Indication: 0
Date: 2015.05.12
Time: 21:13:43
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4702
Hex Value: 0x0019
Hex Value: 0xB8AA
Hex Value: 0x00FF
00276 - ABS Outlet Valve; Rear Left (N136)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 224
Mileage: 178620 km
Time Indication: 0
Date: 2015.05.31
Time: 12:59:48
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4782
Hex Value: 0x0010
Hex Value: 0xB892
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: None
VCID: 55A7F793BCCE60896CD-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 731 B HW: 4E0 035 729
Component: Interfacebox H43 1190
Revision: 00000000 Serial number: 303GM057504574
Coding: 0000003
Shop #: WSC 02335 785 00200
VCID: 214F9343F806DC29405-8074
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H07 0050
Subsystem 2 - Serial number: 00000000196481
Subsystem 3 - Serial number: 0107.07.050000000100010594ÿ
Subsystem 4 - Serial number: 010594ÿ
2 Faults Found:
02244 - Button in Control Head is Stuck
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 224
Mileage: 178601 km
Time Indication: 0
Date: 2015.05.30
Time: 20:22:51
Freeze Frame:
Bin. Bits: 00001000
Bin. Bits: 0000010
Bin. Bits: 000
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 13
Reset counter: 221
Mileage: 177713 km
Time Indication: 0
Date: 2015.05.01
Time: 18:00:24
Freeze Frame:
Bin. Bits: 10
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 S
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000000165208
Coding: 0524326
VCID: 5BB3E1AB9AEAB6F95A9-800E
No fault code found.
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 B HW: 4F0 907 279 B
Component: ILM Fahrer H15 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0010103
VCID: 28598E679B3C2D6107B-807D
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
2 Faults Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01111110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 135640 km
Time Indication: 0
Date: 2011.10.20
Time: 06:34:00
01498 - Bulb for Parking Lamps; Right (M3)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 109
Reset counter: 184
Mileage: 177712 km
Time Indication: 0
Date: 2015.05.01
Time: 17:56:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBE7207203
Shop #: WSC 00000 000 00000
VCID: 1B33A1ABDA6AF6F99A9-804E
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 66 AIRBAG AUDI8RH29 0300
Revision: 12H29000 Serial number: 00359D0A12JJ
Coding: 0013878
Shop #: WSC 22164 444 67032
VCID: 2A5D746F85301F7111F-807F
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME0B0A070E3
Subsystem 3 - Serial number: 6342CSME0A600B5C6
Subsystem 4 - Serial number: 6352QSME022C04456
Subsystem 5 - Serial number: 6362QSME044625335
Subsystem 6 - Serial number: 63734SME04470605R
Subsystem 7 - Serial number: 63834SME044C0C674
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026051890094
Coding: 0002021
Shop #: WSC 02323 785 00200
VCID: 66C5C05F51A8FB11F57-8033
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H11 0630
Revision: 00000000 Serial number: 4R852WD75
Coding: 0019263
Shop #: WSC 22128 444 82895
VCID: 1E35A8BFC978E3D17D7-804B
1 Fault Found:
00438 - Fuel Supply Sensor 2 (G169)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 7
Fault Frequency: 4
Reset counter: 219
Mileage: 178505 km
Time Indication: 0
Date: 2015.05.22
Time: 03:00:00
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H10 0060
Revision: 10 Serial number: 12008057158100
Coding: 6CFE53C51B1104
VCID: 275B8D5B962222190E1-8072
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0050
Revision: 00000000 Serial number: ”‚
Coding: 0035435
VCID: 2C5172778FC40141E33-8079
1 Fault Found:
02115 - Locking Unit for Central Locking
Freeze Frame:
Fault Priority: 3
Fault Frequency: 78
Reset counter: 184
Mileage: 177713 km
Time Indication: 0
Date: 2015.05.01
Time: 17:54:01
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H19 0140
Revision: 01400019 Serial number: 01005732630000
Coding: 4618301
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
5 Faults Found:
01518 - Bulb for Back-Up Lights; Left (M16)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 207
Reset counter: 184
Mileage: 176631 km
Time Indication: 0
Date: 2015.03.29
Time: 14:10:19
02198 - Bulb for Tail Light 2; Left (M49)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 184
Mileage: 176631 km
Time Indication: 0
Date: 2015.03.29
Time: 14:10:44
01502 - Bulb for Rear Fog; Left (L46)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 218
Reset counter: 184
Mileage: 176631 km
Time Indication: 0
Date: 2015.03.29
Time: 14:10:45
02734 - Bulb for Tail Light 3; Left
Freeze Frame:
Fault Priority: 3
Reset counter: 184
Mileage: 176632 km
Time Indication: 0
Date: 2015.03.29
Time: 14:23:37
02742 - Bulb for Brake/Turn Signal Light; Left
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 4
Reset counter: 222
Mileage: 178212 km
Time Indication: 0
Date: 2015.05.09
Time: 22:50:01
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 B HW: 4F0 035 223
Component: Amp.-ASK H09 0270
Revision: 20S00001 Serial number: 01607050125977
Coding: 0000006
VCID: 1D37AFB3C47EF8C964D-8048
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000004819
Coding: 0002114
VCID: 5EB5E8BF89F8A3D13D7-800B
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0050
Revision: 00000000 Serial number: ”‡‚
Coding: 0035435
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 18
Reset counter: 184
Mileage: 177713 km
Time Indication: 0
Date: 2015.05.01
Time: 17:54:00
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
Shop #: WSC 02334 785 00200
VCID: 5DB7EFB384FEB8C924D-8008
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Reset counter: 224
Mileage: 177712 km
Time Indication: 0
Date: 2015.05.01
Time: 18:01:29
Freeze Frame:
Voltage: 12.84 V
Count: 236
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 F HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 394G-057574661
Coding: 0000002
VCID: 2343994BE21ACE39529-8076
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 221
Mileage: 178581 km
Time Indication: 0
Date: 2015.05.30
Time: 16:06:05
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000083649
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 1507140065
Coding: 344630393135313035432056413031353037313430303635
Shop #: WSC 00000 384 00290
5 Faults Found:
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 31
Reset counter: 255
Mileage: 174808 km
Time Indication: 0
Date: 2014.11.30
Time: 18:26:08
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 31
Reset counter: 255
Mileage: 174808 km
Time Indication: 0
Date: 2014.11.30
Time: 18:26:18
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 31
Reset counter: 255
Mileage: 174808 km
Time Indication: 0
Date: 2014.11.30
Time: 18:26:28
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 30
Reset counter: 255
Mileage: 174808 km
Time Indication: 0
Date: 2014.11.30
Time: 18:26:38
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 50
Reset counter: 222
Mileage: 177562 km
Time Indication: 0
Date: 2015.04.29
Time: 01:34:45
Address 62: Door, Rear Left Labels: None
No Faults Found
Old Jun 4, 2015 | 06:39 PM
dnask8man1's Avatar
edit: when i lock the drivers door manually, the key fob will unlcok it, just wont lock the two front doors. I am really confused is there a ccm used for this particular model?
Treatmentroom
Jun 28, 2010 08:05 AM
jessicaAudi
May 11, 2009 10:25 PM
EvilA4
Aug 9, 2008 03:42 PM
